pH Test
I am using 2 Taylor test kits. One is the OTO/pH and the other is FAS-DPD which contains procedures for a lot of different tests. The reading for pH is consistently higher (7.8) on the simple OTO/pH test kit than the more complex Taylor Kit (7.2). This is water from the same sample. Does anyone have a similar experience or does this differece even matter. I appreciate your thoughts
- You may not post replies
- You may not edit your posts
Forum Rules
