Thread: pH Test
    Dec 2005
    Default pH Test
    I am using 2 Taylor test kits. One is the OTO/pH and the other is FAS-DPD which contains procedures for a lot of different tests. The reading for pH is consistently higher (7.8) on the simple OTO/pH test kit than the more complex Taylor Kit (7.2). This is water from the same sample. Does anyone have a similar experience or does this differece even matter. I appreciate your thoughts
    Downingtown, PA
    Default Re: pH Test
    I would trust the FAS-DPD test kit more than the OTO but a good test would be to test a sample with both your test kits then take the same sample water to a couple pool stores. The law of averages *should* help you determine the most accurate number.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    Default Re: pH Test
    intersting. I have a Taylor k-2005 which uses the same pH reagent as the K-2006 (large comparator with 45 ml sample for pH test) and I have Ben's ps234s which has the Taylor pH/OTO test kit in it. I get basically identical results from the two tests. Are you sure you are using the correct reagents for each test? The pH reagent in the K-2006 (which I assume you have) is also used for acid and base demand tests and is different than the one in the K-1000 (or Ben's ps200) and if you use the wrong one you might get wierd results.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
