Results 1 to 10 of 11
Thread: Chlorine level - too low - but why???
    Default Chlorine level - too low - but why???
    FAC = 0
    TAC = 0
    CALC. HARDNESS 220
    CYA = 30 (SO I ADDED CHEM TO RAISE IT ABOVE 30)
    TOTAL ALK = 120
    pH = 7.8
    COPPER, IRON = 0
    PHOSPHATES = 0
    Why can't I maintain chlorine?? This never happens to me.
    I use leslie's trichlor hockey pucks in an inline feeder - just like I’ve done for years and years. Pool is covered and heated. Only trace amounts of green algae. Taylor OT test kit reagents only a year old. Will use my powdered shock only as a last resort due to my commitment to make my new liner stay unbleached and supple. My area is northeast.
    I/g vinyl; 28k gal.; 1.5 hp de filt
    Jul 2013
    Northern Illinois
    Default Re: Chlorine level - too low - but why???
    Pucks will not add chlorine as fast as you need it. I would recommend only using liquid chlorine (bleach, liquid pool shock) for your sanitizer except when going on vacation. Pucks will just raise your CYA even higher. The results of that will be that it will be even harder to maintain chlorine in your pool.
    Go get bleach or liquid chlorine (either from WalMart or Menard's/Home Depot, etc). Add about a half gallon a day. Report your results and let's go from there.
    Trace amounts of algae are too much. I recommend getting a better test kit (Taylor K-2006C). Worth every penny and I promise it will pay for itself over the season.
    I have a relatively new vinyl liner and understand your concern. If you follow the forum's advise, your water will be sparkly clear and your liner will be just fine!
    Added half a gallon of Clorox GERMICIDAL bleach. Home Depot carried that, plus 'outdoor' variety for decks. So far, so good. thanks!
    Jul 2013
    Northern Illinois
    Great! How much did you pay for that? It can be expensive!
    $4.39. Isn't this this part of the cheap, but effective BBB method?
    Jul 2013
    Northern Illinois
    Well, it's a great product, but $4.39/gallon is tough. Many people just use plain, unscented 8.25% laundry bleach. I use pool shock which is the same stuff but at 12.5%. I try not to pay more than $3.00/gallon and sometimes I get it for $1.99/gallon at Menard's on sale. If you're handy at math you can figure out what is the better deal for you. If germicidal was cheaper, more people would use it!
