Re: Solar Panel plumbing and flow rate
The pump is a 2 hp single speed unit as I mentioned in my post. My plumbing manifold is in a horizontal "H" configuration. On the upper horizontal leg, the flow is from right to left from the filter. In the middle of the leg is the 3-position diverter valve, and to the left is the plumbing to the panels. On the lower horizontal leg the flow is from left to right from the panels and through a "T" section. To the right of the "T", the flow goes back to the pool. The vertical leg between the diverter valve and "T" is the bypass, allowing flow directly back to the pool. I have the diverter valve adjusted so that there is zero flow going through the vertical leg and 100% flow going to the left towards the panels. Location wise, the pump / filter is located directly next to the pool and I have 50' of flex PVC going to and from the 20' long panels.
18' x 33' AG pool, 2HP US Motors / PMX pump with 200 # Columbia Sand Filter, (2) 4 x 20 FAFCO Solar Panels
