Results 1 to 10 of 10
Thread: I don't think I got the right stuff
    Jul 2011
    Los Angeles, CA
    Default Re: I don't think I got the right stuff
    I just use a basic test kit with the five liquids. It's what I know to do.
    20,000 gallon plaster (concrete) pool
    DE filter
    Nature 2 (unchanged)
    Jul 2013
    Northern Illinois
    Ok. Give us all your CURRENT results then. (Can't believe I am still awake. Fading fast!)
    Jul 2013
    Northern Illinois
    Well, we need those results to be more specific.
    Get your pH in line (7.2-7.6) if it needs adjusting. 7.2-7.4 is better for now.
    Raise your FC to shock level according to the FC/CYA on the Best Guess Chart: http://www.poolsolutions.com/gd/best...e-chart.html#a
    Keep it at that level by checking the FC and making chlorine additions as often as you are able.
    Then when it seems to be holding fairly well, do an overnight test on your pool. After sunset, make your last addition of the evening and retest your FC an hour or so later. Then, in the morning within an hour of sunrise, check the FC again. If you lose more than 1ppm, then you should keep your FC at shock level.
    When you pass the overnight test, your CC is 0.5 or less, and your water is clear, then keep the FC high for one more day just to make sure.
    Then let the FC fall to your maintenance range, but towards the high side of it so that you don't let the FC get below your minimum.
    Jul 2011
    Los Angeles, CA
    I managed to get the water blue and clear again, but I'm cleaning the filter way too often. I'll keep referring back to this.
    DE filter
    Jul 2013
    Northern Illinois
    Great news! There's probably still some dead algae getting filtered out. Did you pass the overnight test with no more than 1ppm loss of FC and less than .5CC?
    I really don't know anything about DE filters. Here is a guide that PoolDoc wrote. Maybe it will help:
    http://www.poolforum.com/pf2/showthr...ut-Damaging-It!
    Jul 2013
    Northern Illinois
    How are things now?
