Thread: When to add Stabilizer?
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Default When to add Stabilizer?
    My current readins are:
    PH 7.4
    ALK 50
    Chlorine 1.5 (yes, it's low)
    CYA 20
    It's just gotten hot an sunny so I haven't added any stabilizer this yer. Last year I was using tablets, but I dumped them for the BBB method.
    So if I'm right my CYA should be around 40 and my chlorine should be at least 5-7.
    Should I bring my cya up first then bring the chlorine up to at least 5?
    Just trying to make sure I do it in proper order.
    thanks for any tips.
    Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
    Jul 2013
    Northern Illinois
    Default Re: When to add Stabilizer?
    FC is the most important thing for you do do right now. You can add CYA and chlorine at the same time, btw.
    Jun 2013
    Haverhill, MA
    I added more Bleach and cya. Here are my currents levels. I feel these should be good for now.
    I'm at:
    cya 50-55
    chlorine 4.5.
    ph7.4
    alk 60
    Jul 2013
    Northern Illinois
    You want your FC to be around 10% of your CYA. Don't let the FC drop too much lower.
    See: http://www.poolsolutions.com/gd/best...e-chart.html#a
  1. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  2. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  3. Stabilizer ?
    By hannadock in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-26-2010, 10:33 AM
  4. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
  5. cya 0 after nearly 3 1/2 lbs. stabilizer
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2006, 01:53 PM
