Thread: Calcium Hardness Levels for Heater
    Oct 2013
    Rhode Island
    Default Calcium Hardness Levels for Heater
    I have a Hayward Universal heater and the owner's manual recommends keeping CH between 200 and 400. Mine is at 60. Is it really advised to raise CH that high?
    Sharkline Escalade RTR 24' x 54" Round AGP; OptiFlo 2-speed pump; Pentair PLM-100 Cartridge Filter; Hayward 250FDN Heater; Taylor K-2006; AquaIlluminator Return
    Jul 2013
    Northern Illinois
    Default Re: Calcium Hardness Levels for Heater
    Only worry about it if you have a warranty issue. Otherwise, you don't need to raise your CH.
    Oct 2013
    Rhode Island
    My concern was that if I ever need to make a warranty claim, will having low CH be a legitimate reason to deny it? In reading on TFP, it sounds like the "science" behind low calcium being corrosive to metal is rather sketchy. As the theory goes, it is hoped that the calcium forms a protective barrier inside the copper pipes or the calcium decreases the water's affinity for metal. The arguments against this theory are that the calcium carbonate layer doesn't form well inside a heat exchanger (doesn't form well on the cold spots and maybe results in too much scaling on the hot spots) and that taking the calcium out of water (by softening) makes water less conductive and therefore less corrosive (I think).
    Jul 2013
    Northern Illinois
    Yup, that's it. How new is the heater? Since we know you don't NEED the CH, if there's ever an issue, raise the CH (and other requirements) before making the warranty call. Not legal advise here, just saying.... What is your handle on that other place?
    pH is the most important parameter for heater longevity.
    There are also pools over 10 years old reporting on these forums with copper in their gas heaters and ZERO calcium or in some cases very low calcium in their water and they have no problems whatsoever. My own tap water only has 50 ppm CH, but the municipal water district does add 300-500 ppb phosphates for corrosion control, but that's mostly to prevent lead (and to some degree copper) leaching, not so much for preventing corrosion to the extent that there would be leaks. The pH is also kept higher and that's the most important factor to preventing metal corrosion.
    Calcium carbonate saturation is really for protecting surfaces that have calcium carbonate in them including plaster and grout.
    Oct 2013
    Rhode Island
    Thanks chem-geek. I'm learning from your posts. Personally, I changed majors after 3 semesters of Chem-E.
    @FBU: I'm just a lurker at TFP. Heater is only one season old.
    Last edited by bottomcat; 06-01-2015 at 08:26 AM. Reason: addressed to wrong handle
  1. Calcium Hardness
    By elliott4865 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-24-2014, 11:57 AM
  2. calcium hardness
    By walker1 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-08-2012, 11:49 PM
  3. What should Calcium Hardness be?
    By troykristoffer in forum Dealing with Alkalinity and Calcium
    Last Post: 05-31-2007, 12:49 AM
  4. Calcium Hardness
    By Ciscokid in forum Dealing with Alkalinity and Calcium
    Last Post: 05-30-2007, 03:29 AM
  5. Calcium Hardness
    By PaulE10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-15-2006, 11:52 AM
