Results 1 to 10 of 23
Thread: Benchmarking a possibly-expired test kit
    Jul 2013
    Northern Illinois
    Default Re: Benchmarking a possibly-expired test kit
    Yes, some reagents can be of different concentrations. Find out exactly what the pool store has, and then do some research on Taylor's site to see if they say what the equivalents are. You really can't mix and match some of them as they are calibrated to work at the correct strengths.
    Here is the original link I gave you on checking reagents: http://www.taylortechnologies.com/Ch...SP?ContentID=2
    This might help. It's a search for reagents: http://www.taylortechnologies.com/pr...nts_search.asp
    May 2014
    Ottawa, Canada
    Actually, the link you gave me the first time worked. This time it just abbreviated it or something (that autocorrect acting up again?)
    Ok, I just went to look at the specs for R-0007 and holy frijoles... it gave me
    Code:
    A = .75 oz (22 mL), A-24 = .75 oz (24 pack), A144 = .75 oz (144 pack), B = 2 oz (60 mL, wide-mouth),
    C = 2 oz (60 mL), C-12 = 2 oz (12 pack), D = 4 oz, DD = 8 oz, DB = dropper bottle, E = 16 oz, F = 32 oz,
    F4 = 32 oz (4 pack), G = gal, G4 = gal (4 pack), H = 25 g, I = 10 g, II = 50 g, J = .25 lb, K = 1 lb,
    Z = 1,000 pack, Z-10 = 10,000 pack, Z-50 = 50,000 pack
    Is this what I asked for from the pool store guy?
    Everybody into the puel!
    Jul 2013
    Northern Illinois
    Is your current bottle labelled R-0007? If so, then those are just different quantities of the same concentration. You want A, C, or D; 0.75oz, 2oz, and 4oz respectively.
    The cost goes down as the quantity goes up, just like most product packaging. It boils down to what the pool store carries as Taylor is tough to get in Canada. Make sure they have TAYLOR R-0007.
    May 2014
    Ottawa, Canada
    Yes, one of them is "R-0007 THIOSOLFATE N/10". Since but I don't usually use half of a bottle in one season, I might as well get the smallest. As for the concentration: if it's Taylor, it's the right concentration and if it isn't, it's anybody's guess?
    Jul 2013
    Northern Illinois
    You are good if they have TAYLOR R-0007. If they are Taylor reagents and the numbers match, you are good. The letters after R-0007A or R-0007C are just the size designation.
    May 2014
    Ottawa, Canada
    I called Taylor to ask how I know if their reagents are expired, and by using the lot numbers, they were just able to tell me what it is due to expire. Fortunately, everything I have here is good for another season, except the R-0002. I called one local pool store, and they have some Taylor there, but because they don't sell the small bottles, it's more than I want to pay for a single reagent. The thing is, according to http://www.taylortechnologies.com/Ch...SP?ContentID=2 it should be taking on colour to be expired, and the stuff is still clear. So I'm not totally sure what to think.
    I guess I don't see what the problem is with testing.
    You can add 1ml of your LC to 10 liters of tap water (5 x 2 liter soda bottles into a 5 gallon bucket) and it will give you the concentration.
    The idea is that if you do the math, adding 1 gallon of LC to 10,000 gallons of water (or 1 liter of LC to 10,000 liters) the water's FC will be increased by exactly the concentration of the LC, whether it's regular bleach, ultra or LC (5.25%==>5.25ppm of FC, 6%==>6ppm of FC, 12.5%==> 12.5ppm of FC).
    Scaling down to 1 ml of LC to 10,000 ml of water (10 liters) gives the same relationship. And 10 liters is 5 Coke/Pepsi bottles.
    Just remember to subtract any FC the tap water has from you calculation.
