Actually shouldn't have to run anymore than you are now (2). The solar valve would just bridge the two pipes running up the house in a H configuration. The check valve would just be before the H on the supply side. Similar to below. The only difference is the pump and filter is lower than what is shown in the picture. But you only need a supply pipe and a return pipe to and from the house with the diverter valve. Also, they don't show the check valve but you should have that right before the diverter.No, right now everything is below the pool level, and I don't think it is feasible to change that---I would have to run many pipes a long way.
