Closed Thread
Results 1 to 10 of 11
Thread: how to find blockage in recirculation loop
    Oakland, CA
    Default how to find blockage in recirculation loop
    Greetings,
    I am experiencing intermittent blockage of the PVC pipes between
    the filter and the pool. The pressure gauge at the filter shows higher
    than normal pressure, and there is very little flow. If I turn off
    and on the pump several times, the blockage goes away.
    The question is, how do I find where it is? I have examined
    the filter and nothing seems wrong with it. After the filter
    there is a check valve (one-way valve) and I strongly suspect
    that's the culprit. Then there is a three-way valve to optionally
    direct the flow through the solar panels. Then there is a manual
    valve, and then the Pool Pilot chlorine generator.
    Pressure gauges on the web are cheap ($5 to $10).
    I don't mind buying two or three and leaving them
    permanently installed in order to isolate this one problem.
    But they have copper male threads and I don't know
    if there is any simple way of installing them on 1.5"
    PVC pipes. Any suggestions?
    Thanks!
    Luigi Semenzato
    duraleigh Guest
    Default Re: how to find blockage in recirculation loop
    If your pressure guage reads higher during the blockage, the problem is somewhere between the pressure side of the pump and the return eyeballs.
    I would be willing to bet the check valve is the culprit. It is quite hard to get a blockage in PVC pipe - what do you suspect this blockage might be?
    mas985's Avatar
    Pleasanton, CA
    During one of the high pressure moments, leave the pump on and tap lightly with a hammer on the check valve and see if it lets loose. If it is stuck it should swing open and the pressure drop.
    Mark
    Oakland, CA
    Thank you for the advice. I just tried tapping the valve but it didn't have any
    effect. I still suspect the valve, though.
    I tapped reasonably hard but I had to make an educated guess as to how hard
    to avoid cracking the valve casing.
    Oh well, I guess I'll replace the valve and pray that's the problem.
    I will post on this thread as soon as I do it.
    Thanks!
    Luigi
    30'x16' (irregular) indoor gunite/plaster pool, about 10k gal
    Pool Pilot SWCG, 3/4 HP recirc pump, solar panels, heat
    exchanger from 200 BTU/hour Viesmann boiler
    Honesdale PA
    Whacking PVC with a piece of 2x4, not pressure treated, is pretty safe. Pressure treated seems a little harder, but still softer than a hammer. Or, use a piece of PVC pipe.
    Oakland, CA
    Talking Re: how to find blockage in recirculation loop
    Quote Originally Posted by Poconos
    Thanks, I appreciate the PVC-whacking advice.
    I am quickly becoming an expert on whacking PVC.
    I found drawings on the Web on how this particular check valve
    is built. There is just a little door. I am guessing that the door
    doesn't stick completely closed, because there is a tiny bit of flow,
    which varies from run to run. So it may be the hinge. In this
    case it's not clear that further whacking will reveal anything,
    because the door may be required to jiggle a bit to become loose
    (instead of just unsticking from the opening) and the whacking
    is not necessarily going to be effective.
    I found a place that sells *transparent* PVC check valves.
    I am getting one of those so next time I'll know for sure.
    Luigi
    30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
    Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
    solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
    duraleigh Guest
    Hi, Luigi,
    I have never been a fan of check valves......because of the problems they cause.
    Would your system function without one?
    Honesdale PA
    As far as I know there are two kinds of check valves. Spring loaded and flap. Spring loaded are closed even with zero flow. Flap require some minimum flow to operate. Spring type may be sensitive to the chemical makeup of the fluid since they probably have a metal spring. As with Dave, I'm not a fan of check valves. They restrict flow to some degree and are prone to problems such as gunk on the sealing surfaces. They do have their use in specific situations but I think they are over prescribed. Just my quarters worth.
    Oakland, CA
    I am not sure why the valve is there but I have a theory. The filter is one story
    below the pool and two stories below the solar panels. When the pump stops,
    water flows back freely from the solar panels (or they would get scrunched
    by atmospheric pressure). Without a valve, this might cause a backflow through
    the filter housing and possibly back into the pool through the skimmer.
    Having seen how grimey the water is in the dirty side of the filter housing,
    I can see how this should be avoided.
    Luigi
Closed Thread
  1. Pool Skimmer Blockage
    By vbpoollady in forum Intex-type Pool Setup & Operations
    Last Post: 06-19-2012, 08:41 PM
  2. Please help with choosing Loop Loc cover
    By TomC in forum Pool Equipment & Operations
    Last Post: 08-10-2011, 09:30 AM
  3. loop loc prices
    By csamra in forum Pool Equipment & Operations
    Last Post: 07-20-2006, 09:01 AM
  4. Loop-Lock Repair
    By halds in forum Pool Equipment & Operations
    Last Post: 05-11-2006, 02:41 PM
  5. Loop Lock Cover
    By donfranko in forum Pool Equipment & Operations
    Last Post: 04-03-2006, 03:26 PM
