Thread: Overshooting Chlorine...on purpose
    Default Overshooting Chlorine...on purpose
    Hi all, I opened my pool last month (Gunite, 25,000 gallons) and fortunately found this forum before I added any pool store chemicals - (I've had a problem for the past two years keeping my chlorine levels stable...CYA >150!!!!) - been doin' nothin' but bleach and muriatic acid ever since and have a beautiful, crystal pool. CYA is now down to 80. Thanks to all of you.
    Last week was unusually warm for S.E. Pennsylvania and I now believe I am fighting a little something on the floor of the deep end of my pool. (probably happened cause I was still in the learning curve of keeping my CL at around 8-10ppm with a test kit that only went to 5ppm - did figure out dilution method.) Anyway, I've been working to keep my chlorine at shock levels and holding there - but have been sort of "bouncing".
    I think that I may need to target my breakpoint to 25ppm and hold there. I just got an FAS-DPD test so I should be able to do a better job of getting it up there accurately.....finally,
    Here's my question, since my pool is plaster and high CL shouldn't hurt anything, What if I get real nuts with the bleach say, just go for about 30-ish ppm - then I'm sure to hit breakpoint and hover there for a few days and brush, brush, brush....
    What do you think? I thought I saw Duraleigh maybe mention something similar somewhere but couldn't find it when I searched. Thank you.
    Default Re: Overshooting Chlorine...on purpose
    There is a thread in the chlorine section about the same issue. I personally can't see any reason why it would hurt--the reason the Cl is limited in a vinyl pool is to keep from bleaching the liner, but if your pool is plaster and white already, I don't see where it should hurt.......JMHO
    duraleigh Guest
    Smokey,
    To my knowledge, the only restriction in Cl (within reason) would be for vinyl lined pools.
    I would certainly consider 30ppm within reason for a plaster (gunite) pool and your CYA level.
    Measure accurately and test accurately but I think that's exactly what I'd do if it were my pool.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. epsom salt- what purpose does it have
    By vickeybear in forum Intex-type Pool Setup & Operations
    Last Post: 07-14-2012, 12:46 PM
  3. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  4. Purpose of the "eyeball"
    By Rangeball in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 10:14 PM
