I just found a small crack right where the water intake pipe goes into the valve. I figure I will have to get a new one but until then I have put a circular metal clamp over it, is this ok to do??
16X32 Inground 23,000 gal vinyl lined Hayward S200 High Rate Sand Filter Hayward Super Pump 1HP 20GPM 8.25% Bleach for chlorinating.
You should be fine smoovie... As long as its not leaking... But even if it was leaking you can probably stop a severe leak with putting a clamp and piece of rubber of some sort around the crack..
Hope this helps..
Of course a new valve is in order...
12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
You could try some pool epoxy and then the clamp. It will probably still leak but should slow it down significantly. Replacement is best.
