Thread: sand filter replaced
    May 2011
    Tennessee
    Default sand filter replaced
    I have a Hayward Pro Series S-244T and we changed the sand out. The control valve is on properly and the sand is the correct grade. After putting everything back together the water will only filter for about 5 are so and then nothing. The valve and center pipe are properly place back together. I ran it on backwash for 5 minutes then rinse for 60 sec. Any ideas as to what is happening? Thanks
    Default Re: sand filter replaced
    That's 250 lb sand filter? Did you use exactly the right amount of sand and was it specifically pool filter sand?
    Top mount sand filters are fairly simple devices so you don't have many options of places for things to go wrong:
    Sand--too much, too little, wrong kind, gummed up.
    Laterals: Damaged, blocked or not placed properly
    Multi port valve: Damaged, assembled wrong, failed spider gasket, plumbed wrong.
    It's got to be in one of those 3.
  1. Sand for sand filter...obtaining proper kind
    By RonStordahl in forum In-Ground Pool Construction and Repair
    Last Post: 04-23-2014, 01:00 PM
  2. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  3. Replies: 4
    Last Post: 07-25-2011, 06:39 PM
  4. How often should sand in a sand filter be replaced?
    By skywalk1962 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-12-2011, 04:15 PM
  5. Hayward Filter - can a heat exchanger be replaced?
    By Robbin in forum Pool Equipment & Operations
    Last Post: 02-28-2009, 10:47 PM
