Creases on floor
I needed to drain my pool due to algae this spring. I drained (18,000 gal.), cleaned, then started to re-fill. I dont know how I missed it, however, i now notice 2 large creases on the bottom (each creating a flap about 1.5 inch). Unfortunately the pool is about 1/3 full and I cannot straighten out these creases. I'm sure these flaps will fold down due to the weight of the water, but am worried about the liner being pulled and could also have problems vacuuming the pool floor.
Can I get by with these creases or should i just cut my losses, re-drain, straighten the lining, then re-fill.
- You may not post replies
- You may not edit your posts
Forum Rules
