Thread: Adding Muriatic Acid
    Dec 2005
    Orange, CA, USA.
    Default Adding Muriatic Acid
    Currently, once a week I add about 1/2 gallon of acid to my pool to bring it down from 7.8ish to 7.2 It's a new pool (Oct) and I've got a SWC. Was wondering if it's better to add a 1/4 gallon every 3 or so days instead of adding 1/2 a gallon once a week. Could larger doses less often do any "damage" instead of a more steady addition every couple of days?
    Thanks...
    Default
    I have a 6600 gal fiberglass pool with a SWG. My pH tends to stablize at 7.8. When it creeps above I add about 3 cups (24 oz.) of acid and my ph is just below 7.4. It then gradually creeps up to 7.6 over the next two or three weeks and then stays there for another 2 or 3 weeks. As long as it is staying in range of 7.2 to 7.8 I don't worry about it too much. I have used Borax in my poos so the borate/boric acid buffer system will stabilize the pH a bit higher than a bicarbonate/carbonic acid buffer system alone will.
    Houston.
    Default
    I've seen a couple different values, but I think the highest amount suggested was around 20oz per 10,000 gallons max.
    I add to mine (new pool gunite water filled Nov 05 with SWC) a couple times per week. Once a week for me would get me over the suggested max that I mentioned above.
    Robert
  1. adding muriatic acid to covered swg pool
    By lauralou in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-25-2009, 10:36 PM
  2. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  3. How do you add muriatic acid?
    By mohawk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-09-2006, 01:25 PM
  4. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  5. Circulate water or not after adding Muriatic Acid?
    By kennysacht in forum Dealing with Alkalinity and Calcium
    Last Post: 06-05-2006, 05:09 PM
