Results 1 to 10 of 18
Thread: Anyone heard of ipp america or pool maid pool cleaners?
    May 2013
    Concord,ca
    Default Re: Anyone heard of ipp america or pool maid pool cleaners?
    ok swimdaddy, 1. I had to order 2 more hoses took 12 days. 2. I had to order adapters..18.00 another 12 days shipping. 3. I need another adapter for my pool manual sweep 15.00 and another shipping wait. I will know if it works properly it hung up on the steps but when I increased the vacuum it appeared to work itself out. I will see and get back in around 3 days. So far is it worth it? I think if I were able to get what I needed like in a pool store then yeah ok, but I'm not and parts are not interchangeable as far as I can tell. Hopefully
    it will work and not be another garbage pool cleaner that lasts 2-3 years. Will know soon. But if I were you I would wait for my review to you.
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Bummer, sorry about all your troubles. Hopefully it will do the job, and last!
    May 2013
    Concord,ca
    ok swimdaddy, the cleaner works fine. if you buy it make sure you have enough hoses, and if you use a manual also the kind that attaches to your hose the manual wont fit so you need an adapter for that and they have it and sent mine free. Im telling you everything you may need so you wont go through the hassles I did. but again the pool cleaner works fine
  1. America's Best Natural Swimming Holes
    By AnnaK in forum General Interest
    Last Post: 09-03-2012, 04:18 AM
  2. pool cleaners
    By Skioutty in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-11-2011, 09:46 PM
  3. Has anyone heard of a Siverado Pool?
    By Stonedbeetle in forum Above-Ground Pool Construction & Repair
    Last Post: 04-23-2011, 06:00 PM
  4. Safety Covers of America
    By Sheri in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2010, 11:38 AM
  5. anyone heard of Cambria pool?
    By jimmyzshack in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2006, 08:46 AM
