You need a new gauge. It is supposed to zero.Originally Posted by graciec
Our gauge broke at the end of the summer '04
and I went to Lowe's to get another one.
The guy said "this isn't the same" but it will work.
It never goes to zero...when it's shut off it goes to 20
and when I turn it on it stays on about 24. If it goes to 30
then I start watching it and usually backwash.
Does anyone think this is a problem as long as I'm aware
of the variations?
TIA
do they go bad that quickly?Even after 2 years? I just tapped on it in off position and it sprang back to 20 or so but it's back up to 40 now. Are gauges available at pool stores? or do I get one from the company that makes our filter?
They are available in pool stores, and can fail in weeks. They are junk. I put a new one on this year, and it's already bad. Learn how much your returns ripple the water when the filter is clean, and backwash when that rippling is reduced.Originally Posted by graciec
That is an excellent tip! so can I just watch this gauge and know what it marks as normal for now? or is it better to replace? does it need that special tape in the threads that is sometimes used? I will have to see if ours has it now Didn't know they were so junky...thanks
You can order very decent gauges inexpensively from www.mcmastercarr.com.
HTH,
pj
My guage also went after 2 years, just replaced it, tehn took the old guage off, ripped it appart, "reset" it by bending the mechanism inside it until the needle dropped to ) but did not bottom out completely on teh stopper peg.
After this i figured - "yeah right McGyver, I highly doubt this thing will work again". Unscrewed the new (now 15 minutes old) guage, put the old one back in, and voila, EXACTLY the same reading as the new guage gave me seconds earlier.
So, now i have 2 guages that are OK, if one goes, I switch to the other and fix the uncalibrated guage using my new McGyver calibration technique.
