Thread: Pool heat pumps
    May 2013
    Concord,ca
    Default Pool heat pumps
    I have read about solar covers, and solar panels ( which I have ) now Im interested in heat pumps vs gas heaters. I have a 13 k pool and need to take the chill off so as to enjoy the pool. What do those of you who have them think about the benefit. I know it costs more but I probably will use it more for therapy than before. Thanks for chiming in
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Pool heat pumps
    I don't have personal experience but everything I've read says heat pumps are far more efficient and economical to run. Makes sense because the hp sweet spot is when the air temp is in the 50's and higher. Their bad rep is from being used to heat houses where temps go down to the 30's and 20's, where hps work very badly.
    May 2013
    Concord,ca
    thanks Carl great info
    Of course, you have to figure a few other things in:
    1) Initial cost. HPs cost quite a bit more. But they are easier to install, needing only electric, not electric and gas. How long will it take for the cost to be amortized by the fuel savings?
    2) Which ones are the most reliable. Can't help you there.
    3) You can't really run them intermittently as they take far longer to warm up a pool than a gas heater. I think the max BTU is about 125K, with a 100K being typical, while gas heaters go up to 400K BTUs.
    This isn't research but things to watch and check as you do your research. Hope it all helps.
  1. Pumps without power cords, in-ground vs above-ground pumps? Winterizing.
    By pmcdunnough in forum Pool Equipment & Operations
    Last Post: 07-19-2013, 05:46 PM
  2. Pool Pumps
    By RobertPoolCA in forum Pool Equipment & Operations
    Last Post: 05-07-2012, 11:22 PM
  3. CAUTION Leaf Pool Pumps or Eco Pool Pumps or Spectra UV
    By mrrparker in forum The China Shop
    Last Post: 04-07-2012, 05:31 PM
  4. Market for old heat pumps?
    By DanS in forum Pool Equipment & Operations
    Last Post: 09-09-2009, 12:16 PM
  5. Who knows their Hayward/EUS heat pumps???
    By dawndenise in forum Pool Equipment & Operations
    Last Post: 09-09-2009, 12:10 PM
