Results 1 to 3 of 3
Thread: Pump voltage
    Tennessee
    Default Pump voltage
    Had the pool installed this spring and just pluged it in to a 110 gfi with 10 guage extention cord. The pump is a 2hp not sure of the make but here is a link to it and the filter.
    http://www.poolplaceonline.com/10Exp...uctCode=145154
    I will be hard wireing the pump soon. After looking over the book and motor plate I see the pump can be run at 110 or 220 so a few questions.
    Any advantage to running 220 to the pump ?
    Can I run it as a 2 speed by switching between 110 and 220 ?
    I was gonna move the pump and filter back from the pool about 10 feet and run the plumbing under ground with solar heating any problems with this beside the winter freeze issues ?
    24' round 52", Sand filter, 1 1/2 plumbing. 10 psi on gauge after back wash. Not sure of gpm.
    I live in E.TN
    Thanks in advance
    Default Re: Pump voltage
    Quote Originally Posted by medvampire
    Yes. The pump should run a little more efficiently, a little cooler and use less electricity.
    No. It will have no effect. You need a 2 speed pump to run 2 speeds.
    I don't see any, but use hard PVC, not TigerFlex underground and be sure you can purge the plumbing of water AND can add anti-freeze for the winter.
    I live in E.TN
    Thanks in advance
    See my responses.
    Tennessee
    Thanks for the fast reply. I will wire it at 220 then.
    Thanks again
