Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Pump voltage
FAQ
register
Thread:
Pump voltage
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-15-2006
12:32 AM
#3
medvampire
View Profile
View Forum Posts
*Removed User*
Weir Watcher
Tennessee
Re: Pump voltage
Thanks for the fast reply. I will wire it at 220 then.
Thanks again
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Do these work well together?
Creases on floor
aqua-rite cell voltage
By Harley91 in forum Salt Generators (SWCG) & other Chlorine Feeders
2
Last Post:
01-16-2009,
02:37 PM
External Pool Spot Lights - High Voltage or Low Voltage?
By CJDahl in forum In-Ground Pool Construction and Repair
2
Last Post:
01-16-2007,
10:31 PM
Pool / Spa Light Voltage
By gordonhyde in forum In-Ground Pool Construction and Repair
0
Last Post:
10-08-2006,
01:51 PM
SAm and SAL lights and voltage level
By eljefe281 in forum Pool Equipment & Operations
5
Last Post:
07-19-2006,
07:14 PM
Low voltage lighting safe around inground pool?
By joelq in forum Pool Equipment & Operations
6
Last Post:
06-08-2006,
01:51 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
