Closed Thread
Thread: Replacing a 1-year old pump that's seemingly died?
    Jul 2014
    Madison, WI
    Default Re: Replacing a 1-year old pump that's seemingly died?
    Sorry, wrong sub-forum!
    Disassembled the pump, plugged the motor in to see if the impeller would spin (it does.) Started to smoke after a few seconds of spinning, coming out of the back of the motor. It's not totally dead, so I guess that's good?
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    Smoking wires is NEVER good. It almost sounds like you are running a 220v pump on 110v, or vice versa. Smoking means either your brushes or wiring insulation is burning.
    A 1HP IG pump should be fine, but not a 1HP AG pump.
Closed Thread
