Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 48 of 48
Thread: Replacing a motor on a pump, and getting the correct size for your pool?
  1. #41
    Jul 2014
    Madison, WI
    Default Re: Replacing a motor on a pump, and getting the correct size for your pool?
    This is exactly how it was on the original seal with the pump, from the factory. I just put a new seal in when I got the 1st replacement motor.
    I think my wet end has it configured backwards, with the seal part with the spring mounted into the motor mounting plate.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
  2. #42
    Jul 2014
    Madison, WI
    Here's the motor mounting plate. The portion of the seal with the spring is installed here, and the ceramic (white) side faces this half of the seal.
  3. #43
    mas985's Avatar
    Pleasanton, CA
    That is backwards. The spring side goes on the impeller side and the white ceramic goes in the mounting plate. That is what is probably overloading the motor. But you probably have ruined the seal so I would replace it.
    Mark
  4. #44
    Jul 2014
    Madison, WI
    It doesn't, though. The spring side won't fit in the impeller (too big) and the ceramic side is WAY too small to go in the mounting plate.
    I'm guessing this wet end is backwards compared to most others?
  5. #45
    Jul 2014
    Madison, WI
    Mounting plate close up:
    Spring on impeller, which doesn't fit:
  6. #46
    mas985's Avatar
    Pleasanton, CA
    My mistake. Waterway evidently decided to do things differently than most pumps and flip the seal. I just assumed they were the same and I shouldn't have.
    You had the seals installed correctly although you need to make sure the white ceramic seal is bottomed in the impeller. The surfaces need to be perfectly parallel when they meet. Also check the seal surfaces for any damage.
    Mark
  7. #47
    Jul 2014
    Madison, WI
    Should there be an o-ring or any sort of silicone sealant behind the spring seal?
  8. #48
    mas985's Avatar
    Pleasanton, CA
    That should have a rubber seat so it should just be clean on both sides. They do make seal lube that is designed so the seals insert easier but it is not a sealant. In fact, you want to avoid and sealant to prevent issues with the seals. Only use the lube that is designed for the seal but that should only go in the rubber parts and not the seals themselves. Those need to be kept clean of everything.
    Mark
  1. Replacing a Dead Pump Motor
    By Peabody in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 12:46 AM
  2. Replacing pump motor
    By bbsmith in forum Pool Equipment & Operations
    Last Post: 04-27-2012, 11:51 AM
  3. Correct Pump Size for Filter
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 11:27 AM
  4. Need advice for correct size AG pump/filter!
    By seadogg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2008, 03:38 AM
  5. Replacing Pump Motor Only
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 10:43 AM
