Re: Replacing a motor on a pump, and getting the correct size for your pool?
Been running for a while, and it's fairly hot to the touch, and I'm only seeing 12 psi at the filter. However, the skimmer is sucking things in at a rate like I've never seen before, so I guess the suction seems to be working well there. Should I be worried about the pump being too hot, or is that pretty normal?
26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
