Re: Replacing a motor on a pump, and getting the correct size for your pool?
I did just take everything apart to get things ready for a warranty replacement motor to arrive tomorrow. I did notice the above, that this seal was slightly crooked. Could this cause a major problem?
I never noticed any odd sound until just after I hooked up the pump to some plumbing I re-did (took out two shutoff a and replaced them with a pair of 3-way valves.) Everything seemed fine until a few minutes after running the pump. It was struggling to reach full prime, and it might have been because the water level was too low (pulled all the water out of the skimmer), so I shut it off and filled the pool up a few extra inches over the course of 3 hours. Turned it back on later that night and it sounded really funny, with a sort of him to it like it was seizing up.
FWIW, the pump had run fine for a full week up until I decided to change up the plumbing in an attempt to convert a vac line to an either/or line (vac or return.) There may have been a problem in the height of the new plumbing to the first valve, which was about 8-10" above the pump intake port.
26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
