Re: Replacing a motor on a pump, and getting the correct size for your pool?
It doesn't, though. The spring side won't fit in the impeller (too big) and the ceramic side is WAY too small to go in the mounting plate.
I'm guessing this wet end is backwards compared to most others?
26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
