Results 1 to 10 of 48
Thread: Replacing a motor on a pump, and getting the correct size for your pool?
    Jul 2014
    Madison, WI
    Default Re: Replacing a motor on a pump, and getting the correct size for your pool?
    Mounting plate close up:
    Spring on impeller, which doesn't fit:
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    mas985's Avatar
    Pleasanton, CA
    My mistake. Waterway evidently decided to do things differently than most pumps and flip the seal. I just assumed they were the same and I shouldn't have.
    You had the seals installed correctly although you need to make sure the white ceramic seal is bottomed in the impeller. The surfaces need to be perfectly parallel when they meet. Also check the seal surfaces for any damage.
    Mark
    Jul 2014
    Madison, WI
    Should there be an o-ring or any sort of silicone sealant behind the spring seal?
    mas985's Avatar
    Pleasanton, CA
    That should have a rubber seat so it should just be clean on both sides. They do make seal lube that is designed so the seals insert easier but it is not a sealant. In fact, you want to avoid and sealant to prevent issues with the seals. Only use the lube that is designed for the seal but that should only go in the rubber parts and not the seals themselves. Those need to be kept clean of everything.
    Mark
  1. Replacing a Dead Pump Motor
    By Peabody in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 12:46 AM
  2. Replacing pump motor
    By bbsmith in forum Pool Equipment & Operations
    Last Post: 04-27-2012, 11:51 AM
  3. Correct Pump Size for Filter
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 11:27 AM
  4. Need advice for correct size AG pump/filter!
    By seadogg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2008, 03:38 AM
  5. Replacing Pump Motor Only
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 10:43 AM
