Re: Pentair intelliflo question
It wouldn't be in the pump's directions. The timer, whether built into your electrical panel or at the pump's outlet, is a separate product.
I have a mechanical timer in my basement with a moving dial. You attach clips to it that turn the power on and off. I just take off all the clips and flip the actuated switch to "on" for 24/7 running.
