Thread: DE is Blue Color
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default DE is Blue Color
    Just cleaned out my filter and was surprised to see that the DE was a blue color . I have used some algae treatment this year that was a dark blue in color but would be surprised it would turn the DE this color . This is the first time in about 8 weeks I have changed the earth . Anything to be concerned about or anything to look for ? I had this once befoe but then was also getting some staining on the steps etc. Did a metal clean up and have been good since .
    16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
    Been on bleach since 2012
    Jul 2013
    Northern Illinois
    Default Re: DE is Blue Color
    What algae treatment did you use? It might have had copper in it which "stains" a blueish color.
    May 2010
    Pennsylvania
    Bingo---in the swim black algaecide treatment 11.4% copper sulfate pentahydrate. So will this mean also metal staining as I dont see any?
    I have been fighting for a few years what appears to be black algae stains at various places on the bottom . I think it is coming from the underside of the liner per everything I have researched. We have had a extremely wet summer in Pa and without a doubt have water under the liner and this is when it always appear. If I treat with shock it will lighten but not completely remove and it will get darker each day .Did not appear to be present at opening in April
