Thread: Pool Heating Math
    May 2010
    Default Re: Pool Heating Math
    Carl,
    Thank you for the reply!
    If I do not use propane then I have to use a heat pump, but the largest heat pump I can find is less than 200,000 BTUs at top efficiency and conditions.
    My decision is to spend 2X as much for the heater, have a lot more parts to break, but hopefully make back savings on energy with a heat pump - if electric rates do not rise over the life of the heater. I used to own a diesel car thinking that form of energy would be cheaper and paying more for the diesel engine option was a good idea. Ha... wrong!
    The pool installer claims he has plenty of unhappy customers with heat pumps because in St. Louis, MO USA there are many days when environmental conditions are not right for a heat pump to work well. I think it has to be above 50 degree or maybe even warmer.
    All comments appreciated. Thank you!
    You last point is key and requires an answer to the question: How cold outside are you looking to overcome and actually swim in? For me, in NJ, there's NO WAY I want to go swimming in my pool when it's below 75, much less when it's below 50. For MY needs (and mine alone), I would never use a heat pump to heat my pool when it was in the 40's (that's what below 50 implies). I don't know where the "sweet spot" for heat pumps is, but I don't think it's there.
    If, OTOH, you are looking to keep your pool evenly warm and maybe extend your swim season at both the front and back end, that's a different decision tree. I use solar and it allows us to swim, in NJ, usually from early May till late September, rather than than traditional Memorial Day to Labor Day season. For that, a heat pump should EASILY cost far less to run than a gas heater. But if you want to heat and swim in your pool in the 40's and below, then a natural gas heater is probably the cheapest to run, followed by a propane heater.
