Results 1 to 3 of 3
Thread: DE is Blue Color
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Default DE is Blue Color
    Just cleaned out my filter and was surprised to see that the DE was a blue color . I have used some algae treatment this year that was a dark blue in color but would be surprised it would turn the DE this color . This is the first time in about 8 weeks I have changed the earth . Anything to be concerned about or anything to look for ? I had this once befoe but then was also getting some staining on the steps etc. Did a metal clean up and have been good since .
    16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
    Been on bleach since 2012
    Jul 2013
    Northern Illinois
    Default Re: DE is Blue Color
    What algae treatment did you use? It might have had copper in it which "stains" a blueish color.
    26K gal 20x40 rectangular IG vinyl pool; Apr 2014: New pump, liner, auto-cover, & water; Pentair Whisperflo 1HP pump; Pentair Trition sand filter; Cover/Star CS-500 auto cover; Taylor K-2006C; OTO
    May 2010
    Pennsylvania
    Bingo---in the swim black algaecide treatment 11.4% copper sulfate pentahydrate. So will this mean also metal staining as I dont see any?
    I have been fighting for a few years what appears to be black algae stains at various places on the bottom . I think it is coming from the underside of the liner per everything I have researched. We have had a extremely wet summer in Pa and without a doubt have water under the liner and this is when it always appear. If I treat with shock it will lighten but not completely remove and it will get darker each day .Did not appear to be present at opening in April
  1. Color Splash / Color Logic Replacement LED Ligths
    By shutitdown in forum Pool Equipment & Operations
    Last Post: 06-22-2012, 01:59 AM
  2. Any experience with Royal Blue color pool paint?
    By allena2s2 in forum In-Ground Pool Construction and Repair
    Last Post: 04-09-2011, 03:08 AM
  3. Pebble Sheen "Cool Blue" Color
    By Poolboyz in forum In-Ground Pool Construction and Repair
    Last Post: 07-12-2006, 08:24 PM
  4. 2 Jandy Color Pool Lights/1 Color Spa Light not synced
    By dc in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 05:36 PM
  5. 2 Jandy Color Pool Lights/1 Color Spa Light
    By dc in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 12:19 AM
