Thread: Pentair intelliflo question
    May 2013
    Concord,ca
    Default Pentair intelliflo question
    I would like to run pump 24-7 but cant find out how in the directions. This is for cleaning. Sorry im not yelling keyboard is messed up. Thanks dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Pentair intelliflo question
    It wouldn't be in the pump's directions. The timer, whether built into your electrical panel or at the pump's outlet, is a separate product.
    I have a mechanical timer in my basement with a moving dial. You attach clips to it that turn the power on and off. I just take off all the clips and flip the actuated switch to "on" for 24/7 running.
    May 2013
    Concord,ca
    before I bought a variable speed I had a simple dial ( which I wish I still did). the people at Pentair said I could only run at 23 hours 59 minutes then reset sounds crazy. Thanks Carl
