Re: Domestic pool turnover rates
I have an automatic electric safety cover that is on all the time except when the pool is in use. The pool is used almost every day for about an hour or two. And yes, having a solar system without a pool cover will have less benefit. Basically, with no cover then overnight in the non-peak of the swim season I can lose 6ºF but with the thin non-insulating but opaque cover I lose 3ºF. If I had an insulating bubble-type cover, I'd lose around 1.5ºF.
The solar panels on the roof pick up the sun's energy directly so our attic is cool when they are running and is a side benefit to keeping the house cooler as well (though the attic is fairly well insulated from the house interior). It's more efficient to have the panels on the roof than it would be having them in the attic. For maximum efficiency in the attic one would want very dark roof tiles thermally connected to the attic. The fact that our synthetic shingles are gray and not black has them not absorb as much heat as the black solar panels and they do not transfer the heat as efficiently to the attic through the roofing materials. Roof attic heating is not an efficient solution unless the roof was designed specifically for that purpose -- it's not that such systems don't work, but that they aren't as efficient as panels on the roof.
15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
