Results 1 to 10 of 43
Thread: Domestic pool turnover rates
Threaded View
  1. #2
    mas985's Avatar
    Pleasanton, CA
    Default Re: Domestic pool turnover rates
    Quote Originally Posted by Teapot View Post
    The chlorine kills what it can in under a minute, what isn't killed by chlorine has to be filtered out. How quickly should this be filtered out? should it be a hour or 8 hours? If the filtration isn't good enough then the whole lot is just recirculated so you spend on electricity achieving very little.
    I am not sure what you meant by this but you really shouldn't try to filter out live bacteria or live algae or it will clog the filter. The only thing that should be filtered out of a pool are dead organics and debris.
    As for turbidity, I run for only 2-4 hours per day and have never had any signs of turbidity. I don't think it is a real issue for most pools.
    Mark
