Closed Thread
Results 1 to 8 of 8
Thread: Springtails? Water fleas?
    Dec 2005
    Orange, CA, USA.
    Default Re: Springtails? Water fleas?
    Springtails love moisture, so make sure any plant areas near the pool are not over watered. I have a problem with them in the Spring when it rains and the plant bed near the rear of the pool stays in the shade. Poof.. they all come out. Our landscaper told us about "Cyfluthrin" which is very effective in killing them (in the garden/grass not pool). Bifen Granules work as well, but not available in CA where I live. Again, I don't have first hand experience using them, just what I was told by someone in the landscape business. My problem goes away in May since the plant area gets full sun all day and dries up quick.
    Wanted to update...they are gone!!! Yipee
    Thank you for the replies and information that they were likely temporary. I was having nightmares of having beautiful clear pool but being too grossed out to enjoy it because of an in infestation of tiny little critters!
    We have gone from a cool wet spring to a warm dry summer and they have vanished without any help from me. Again thanks for the replies, this is a great resource.
    Chris
    Houston.
    Chris,
    See the picture in this thread. Is this what your bugs looked like?
    http://www.poolforum.com/pf2/showthr...?t=1376&page=2
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
    Robert
    My bugs looked darker (more black than tan). They were teensy like yours however, and they appeared to be shaped like a grain of rice (only about the size of a flea) I think they have antennae too, although I didn't dig out the magnifying glass...
    Ours have returned (although not as bad as earlier in the season) and seem to be related to how rainy it has been. We had a rainy spring, and they showed up. When it dried out, they disappeared, and now that it has been really damp again, they have returned, but in fewer numbers. I am hoping with a dry weekend in the forcast, they will pack up and leave again.
    I didn't do anything to get rid of them (aside from the occasional spraying with a dilute solution of dawn, which knocked them off the wall and into the water, where they promptly drowned due to the detergent effect on surface tension, however this reduction in number was only temporary). Mine hung out just above the water line, and would hop from the wall to the pool and back again. I probably should have tried shocking, but I couldn't believe it would kill them because they spent so little time in the water. However, that said, I have witnessed the miracle of bleach on our black pool this spring when we opened, so I would give it a shot if they are really putting a damper on your swimming. Ours were congregating mostly in a corner, and since it was early in the season (and cold and rain) they didn't effect our swimming much.
    Good luck
    Chris
    oh, and try googling for "springtails" and select images, there are lots of pictures of them there
Closed Thread
