Thread: On/off and hi/low speed timer scheduling suggestions?
    Anonymous [GDPR] European in the UK Guest
    Default Re: On/off and hi/low speed timer scheduling suggestions?
    What does the 2 hours on high speed achieve?
    Jul 2014
    Madison, WI
    Skimming the surface, 2x per day.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    If you notice a difference, go for it. If you don't you're simply wasting $$$ on electric. Ironically, sand filters are usually MORE effective when run on low speed. Adding a touch of DE to your sand filter can improve filtration.
    Quote Originally Posted by mitchryan912 View Post
    Not really needed, it just uses up electricity as Carl said and can push the fine collected particles in the sand filter out into the pool again.
    It's not ironic, most filtration works better when you don't apply a pressure of 14PSI to force the dirt through it.
    It's not an RO membrane filter which is where pressure is needed.
    I'm sorry but this is an absurd post. How do YOU know how effective Mitch's skimming is at low speed in Madison, Wisconsin when you're in the UK?
    That is NOT what I said! I said if it WORKS, then go for it. Only if it doesn't work is it a waste.
    Your filtration formula doesn't take into account the different sizes or types of filters.
    I hate to say this, but if you continue to make blanket assertions like "most filtration works better when you don't apply a pressure of 14PSI to force the dirt through it" without supporting them I may have to take action. This is your second warning.
