Thread: Skimmer
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Skimmer
    I have an above ground pool and the skimmer door keeps getting stuck closed and then limits water into the skimmer, cause air intake.
    Is there a reason why that door getting stuck closed???? The water level is a little lower than normal could that be the reason, or something else???
    Barry
    Default Re: Skimmer
    Lots of reasons:
    The door could be inserted wrong--take it out and re-insert it.
    The foam in it could have slipped--even it out.
    The door could be damaged--replace it.
    The door could be the wrong door--replace it.
    Something on the side of the skimmer is causing it to rub--fix it.
    Get your water level high enough.
    Probably some more, too.
