Results 1 to 10 of 20
Thread: Question about CH Test Coloration
    Default Re: Question about CH Test Coloration
    Scaling from LOW calcium?????
    Usually it is from too high calcium and too high T/A
    Aug 2014
    Chelsea AL
    That was something I read. I'm definitely not saying it's accurate. The way they explained it was calcium would be pulled from the plaster if the level in the pool was too low. I take it from you reply though that it likely not true. :-)
    Pulling calcium from the walls is true if calcium is too low. But scaling is from too high calcium.
    Aug 2014
    Chelsea AL
    Ah okay. Gotcha. I think I may go to the dreaded pool store tomorrow just to compare their readings of the water to mine. I'm curious to see how closely I am interpreting things. :-) How about that other thing I asked above....My PH was low so according to the pool calculator, which BTW I like so much that I bought the app today, so I added the suggestion amount of Borax. How long should I wait to retest ph? I ask because I went ahead and retested after about 2 hours and now the Ph is off the chart high. I'm hoping that is because I am just too impatient.
    what is your pH? Anything between 7.2-7.8 is do-able and not too bad
    Aug 2014
    Chelsea AL
    As far as the pH goes my test before adding the borax was 7.0. The calculator said to add 67 ounces so I did. Two hours later the reading was so dark that I'd say it's over 8.0.
    On the calcium test it took me a little while to figure out what you meant when you said "old reagents" I bought this kit during the winter but I did leave it ouside all winter. I didn't know I wasn't supposed to do that until recently. This is the color "red" that I get...
    Aug 2014
    Chelsea AL
    I know the lighting is terrible in my house but this is the color after 40 drops...
  1. First test and a Question
    By vchords in forum DPD-FAS based testing
    Last Post: 06-20-2006, 03:55 PM
  2. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
  3. CC test question
    By vanhout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2006, 02:07 PM
  4. Oto Test Kit Question
    By sisie5 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2006, 10:55 AM
  5. question about Cal test
    By salinda in forum DPD-FAS based testing
    Last Post: 04-23-2006, 09:01 AM
