Re: ARGHHHHH!!! Cloudy water
If you don't have a waste hose, you can use any hose that will fit tightly over the waste port on your filter (usually the back side). I use a short hose
that came with my pool for the aquabug cleaner, it has 8 four ft. sections that fit together. That way I can see it coming out of the hose instead of watching the little plastic window. I just attach to waste port and backwash...DON'T FORGET to STOP PUMP and move lever to RINSE before turning back to filter! I forgot that once when I started all this pool stuff last summer and blew alot of dirt back into the pool!
Main thing is to keep Cl levels up....I personally think a high cl level is better than a low when shocking....and my "bleach line" shows it on the liner. I just add water above the line and I feel alot better. Point is, if you don't keep levels high, you'll never get rid of the algae. It's much easier to maintain a good range than mess with shocking and consequently having to add muratic acid to lower pH. You'll notice as you add chlorine for shocking, it will raise pH...which is better kept at about 7.4-7.6 I only add Chlorine, muratic acid or water to my pool. You can swim in pond water...just don't drink it! good luck!
