Results 1 to 4 of 4
Thread: Liner wrinkles
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Liner wrinkles
    I have an above ground pool, 18x33, and started to notice my liner at the bottom of my pool is starting to "wrinkle" in places.
    What could be causing that??
    Tunneling ants???
    Default Re: Liner wrinkles
    More likely shifting ground. Much ground water?
    California
    Wrinkling of vinyl can also occur from low pH conditions such as using granular Trichlor that sits at the bottom, but I presume you use chlorinating liquid or bleach as your primary source of chlorine and haven't added any such powdered chemicals to your pool, correct?
    15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
    Pouring Muriatic Acid directly into the shallow end of your pool can also cause wrinkling as the acid attacks the liner. Always dilute it in a bucket first before adding it to your pool.
