Re: CYA present in sodium dichlor?
DiChlor (normally) does have CYA. I use it in my spa and the CYA levels rise to the point where I have to drain & refill every 2 to 3 months (CYA was over 400 before my last refill).
It would help if you would post the brand, container size and exact wording on the container regarding adding stabilizer. It would be interesting to follow up.
