Thread: Constantly recalibrating a swimpure
    May 2014
    Venice, FL
    Default Constantly recalibrating a swimpure
    I have a T-Cell 15 that is around 4 years old. I am running into a problem where the salt level is not registering properly. My salt is at 3200 but it keeps showing much lower than that to where the salt generator turns off.
    If I recalibrate back to 3200, it seems to generate chlorine for a day or two, then the it recalibrates back down to where the salt generation turns off.
    I have cleaned the unit but it doesn't seem to make a difference.
    My question is, does this mean the unit is going bad or the controller or a censor????
    Virginia
    Default Re: Constantly recalibrating a swimpure
    Could be a sign the cell is dying. I've replaced 2 cells and each time I got false low salt readings when they died.
    May 2014
    Venice, FL
    Thanks for the response. That was what I was thinking.
    I may just keep recalibrating the thing every couple of days until it produces no more chlorine.
  1. Hayward Swimpure : Should I replace cell, board, or entire unit.
    By TheGoose in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-09-2015, 04:00 PM
  2. Hayward Swimpure + No Flow Light Flashing vs. Solid
    By raddrider in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-26-2013, 08:58 PM
  3. Review-Hayward Swimpure SWCG up to 40,000 gallons
    Last Post: 08-23-2011, 10:03 PM
  4. "pH UP" Constantly Needed...
    By OhAllWet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-17-2006, 05:24 PM
