Results 1 to 10 of 13
Thread: Help, even bleach disappears
    atlanta
    Default Re: Help, even bleach disappears
    Sorry Carl. I tried to give all the relevant info. I did say 28k vinyl. 28000 gallons that is. Also the bleach 8.25 percent sodium hypochlorite from walmart. The shock is from walmart as well "pool essentials" and is trichlor. I am testing with the Taylor kit as recommended here, don't remember the exact numbers of the kit, but uses 5 drops 0001 and 5 drops 0002. You know the one that turns pink rather than the cheaper ones that turn yellow.
    Sorry, missed the first part.
    What you are describing is a DPD chlorine test kit, vs an OTO test kit. DPD bleaches out at above 10ppm but usually around 15, but maybe sooner. The DPD Taylor kit is K-2005, not the K-2006 that we recommend. The difference is that the K-2006 uses the FAS-DPD chlorine test, not the DPD test. FAS-DPD can test to 50 or even 100ppm, and uses a powder first, then a liquid in a brown opaque bottle. The powder is, R-0870 and the brown bottle is R-0871.
    If you're throwing in bags of Tri-chlor powder then I'll bet your CYA is now far higher than 70ppm. Trichlor adds 6ppm of CYA for ever 10ppm of chlorine. Stop using it. Don't use Di-chlor powder either.
    If your Calcium level isn't too high, you can use cal-hypo--but the WalMart stuff is 48%--worthless. You'll need something over 60% or more.
    So...Here's what I am GUESSING is going on
    1) You're bleaching out a DPD chlorine test
    2) Your CYA is now much higher than you measured, meaning, your chlorine isn't anything close to shock level for the CYA level.
    Somewhere around here we have a key to the darker colors of the OTO (yellow) test kit. If you have an OTO kit, using distilled water you can double, triple or quadruple its range. And if it goes to "5" for chlorine, that means you can measure to 10, 15, or 20ppm.
    Just mix equal amounts of pool water to distilled (I like to use a shot glass) and mix. In the OTO test if it says "5" it is now 10. If you mix 2 shots of distilled to one of pool water, "5" means 15. 3 shots--20.
    atlanta
    That is what I was doing with my test kit. I took 4 ounces of pool water and added 12 ounces of tap water from the faucet (I know should have used distilled). Then I tested it to read around 4. Multiplied the 4 times 4 and translated that to read 16. Does this not work with that type kit? Even if I use distilled water? What about Kroger purified drinking water? I do not have the OTO test kit. I would be more likely to order the reagents you described above. Where can I get cal hypo?
    I don't know that dilution works with the DPD test. And, you should test the tap water FIRST before you use it to dilute...if it has a chlorine level it will add it. Same for the Kroger water.
    Distilled water is sold in every grocery and chain drug store, so it's easy to get. Also, OTO kits are sold just about everywhere. But the BEST that is sold in retail stores is at Leslies--it's Taylor's own OTO kit, in a Leslie box.
    Another really good one is the HTH 5-way drop test kit sold at WalMart (may be called a 6-way drop test kit now). It's an OTO kit as well but it's tests for pH, TA and CYA are pretty much as good as Taylor's.
    The FAS-DPD test is sold as a stand-alone test by Taylor. I believe it's the K-1515--and using it with the K-2005 for the chlorine test instead of the DPD test makes the K-2005 the same as the K-2006.
    Cal-Hypo powder is sold in pool stores, including WalMart (but not the stronger stuff).
    There are Leslies stores all over the Atlanta area, but only one inside the beltway.
    It's not that I'm a big fan of Leslies--but that they are the ONLY ones that sell exclusively Taylor drop test kits, even when they are badged (and overpriced) as Leslies own. And the quality of their pool chems is usually good, if also overpriced.
    Personally, I found a store years ago that sells 12.5% Liquid Chlorine (same as bleach only stronger) in 5 gallon carboys for $20. They cater to pool maint services so their turnover is tremendous and their stuff always tests at 14% or higher. I use that. They are a good drive but I combine errands when I go there--Orthopedist, electronics supply store, Harbor Freight, better Home Depot than my local one, etc.
    atlanta
    ok, you were right. My test shows cya at 100 now, maybe a little higher. It is cloudy now and drizzling so the sun is not out. I tested again using Kroger purified drinking water, sorry forgot to buy distilled when I went back to Kroger for more bleach. My test showed around 20 ppm chlorine and like I said 100 on the cya. I am a few inches short on water level right now so I am hoping these several days of rain predicted will refill it for me. If not when I top off I will dump a little and get the cya down to around 80 again. I noticed you did not comment on the algae I always seem to have in the liner clip around the steps. I assume this is not normal but I have had it for years. Also, a co-worker has a similar set up as mine, de filter, goldline swcg, but 40000 gallons vinyl to my 28000. He claims to run his pump and swcg only 6 hours per day. I have to run mine for 12 to 14 hours and still have no chlorine. He claims to read a constant 4 with his system and run time. Is this possible? The Hayward people told me that the t15 system would have to run at 100% 24/7 to make enough chlorine to keep a 40000 gal pool at 3ppm. He told me that mine should then have to run about 28/40(or 16.8 hours) to keep my pool at 3ppm. If this is true, it makes me want to run dual swcg systems so I can cut down on the run time. With the above readings, have I reached shock level at 20ppm? Do I need to dump some water tomorrow and do the whole thing over again with a lower cya? Thanks for all your help by the way!
    Ok. I'm not an expert on persistent black algae, but I can tell you that you need to get your chlorine level up even further, to 25, and keep it there for a number of days before it will stop crashing on you.
    Will it get rid of the black algae? I don't know, but you need to brush it daily to have a hope.
    I cannot really comment on what Hayward told your friend as it makes no sense whatsover and something must be garbled in translation. There are just too many inconsistencies. I'm no SWCG expert either but I know enough. The t-15 is their biggest cell, designed for pools up to 40K (though you usually want to go bigger than the pool). 3ppm of FC is the normal production level for just about any SWCG and should be matched with a CYA of 60. For the cell to have to run at 100% 24/7 to produce that just doesn't add up. Do you both have the same controller as well?
    atlanta
    Ok, I have five new gallons of bleach. I will go back down and bump it up to 25 or so. These several days of rain may come in handy to keep the sun at bay and allow me to pull this off. The Hayward story came to me directly from the Hayward tech support via a phone call. The story about my friend was the fact that he runs his for six hours, and yes we both have the goldline aquarite system. He runs a Hayward cell and I am running a compupool, that is the only difference other than the size of the pools. I have run Hayward cells in the past and I have not seen any difference between the two, other than price. Maybe I need to go back to the brand name cell, who knows.
