Still trying to get balance
I am fighting very high CYA numbers. When I started the pool company reading was 192. I have drained about 4 inches of water off 3 times and purchased a drops test kit. Todays readings are listed below. Please give me guidance as to what to do. When I tested the CYA after the second refill it was down to 100. I have not tested after the third refill. I have had the pool for 6 years but have always just taken the water to the pool store and followed their directions so really, I am just learning to manage the chemicals. I have I think I may need to add bleach to raise the free clorine? The water looks and feels great. I do have a staining problem and will treat with stain out or something similar once I get the balance correct.
Thanks for you help. I have spent a lot of time reading and you guys do a great job of simplifying all of this and do not seem to tire of newbie questions. I am glad I found you all!
CL 4
TA 170
Ph 7.6
Hardness 0
