Results 1 to 10 of 11
Thread: PH Levels after Newly Plastered Pool
    Default Re: PH Levels after Newly Plastered Pool
    The lower TA should help. As the concrete cures the rising pH should end. Do you have anything like a waterfall or fountain or other water effects? They all create aeration which tends to raise pH (but doesn't raise TA--that's why we use it in our TA-lowering strategy).
    markphin is offline Registered+ Thread Analyst markphin 1 star
    No fountains. A spillover from the hot tub though. Yeah, I'm sure the PH will stabelize eventually. I just didn't think it would take this long. I'm hoping it stabelizes by the time I winterize in another month or so.
    The spillover could well be part of the reason for a rising pH, because it will aerate the water.
    I kind of doubt it, as prior to the replastering, I have had little rise in PH over the couse of the previous 13 years. If I put a gallon of acid in a summer it was a lot. I think its primarily due to the curing of the new plaster. Perhpas the aeration is adding to it a bit though. I guess I just have to be patient and wait it out. Hopefully not to much longer though.
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    @markphin: I am about 5 weeks post a re-plaster with krystalkrete. For the first 3-4 weeks, I was adding a similar amount of muriatic acid as you were. I was brushing the surface twice a day; however, a lot of the plaster dust was staying in the deep end near the main drain. Once I hit the 30 day mark and used my pool vac, I was able to vacuum any excess plaster dust. Since removing the plaster dust, the pH has stabilized. While the plaster continues to cure over the next 6 months, I still expect the pH to slightly fluctuate.
    Make sure to test your water regularly.
    Have you seen your pH stabilize? I realize this thread is almost a year old.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
