Results 1 to 10 of 18
Thread: Weighing down Wedding Cake Steps ?
    Joliet
    Default Re: Weighing down Wedding Cake Steps ?
    We've had bad luck with the large sand filled ziplocks and with the weights too. This year I plan to fill some empty bleach and milk jugs with concrete...it should do the trick.
    dan
    Carterville,IL
    Hi guys....just an idea to weigh your steps down safely. We got 3 pieces of 3-4 inch pvc capped off one end w/ pvc cleaner and adhesive. Then we filled the tubes with driveway rock and capped off the other end. THis makes for a clean, easy way to weigh down the front end. Easy to remove.....just make sure you glue the ends on well. The rails that you attach to wedding cake steps help hold down the back end, if you need more help there, make a few more and drill small holes through the top part of the back opening and concoct a way to hang a few more. There is a few pix on this site of someone who had done that. Just an FYI.. hope this helps.
    30' Esther Williams Classic Granite
    Installed july 2006
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    I gave up on the sand bags wrapped in plastic bags. Too much of a mess - the bags always leaked and disentigrated. I use three large oval and rounded river boulders - about 20 to 30 pounds each - that I got a a rock supply place.
    They do grow algae, but so did the sand bags. I don't see a difference in the algae problem - there is less of a mess, the rocks don't break open and leak sand all over the place when you take them out at pool closing. For this reason, the rocks are easier to take out then the bags were. I might chnage my mind in the future - I've got a 16 yr old helper now ... :-)
    The rocks I got are rounded with no nicks or edges. I space them around the bottom of the steps.
    rferrel1 Guest
    Question Re: Weighing down Wedding Cake Steps ?
    Another questions but on the same lines - I decided to reposition my wedding cake steps this year towards one end of where the deck joins the 15' straight side of my 15x30' oval pool. Last year we had it in the center and the "rule" was that my 6yo grandson was NOT to jump in on the side where the steps "flared out". I decided this year we'd try them all the way to one end of the deck so that wouldn't be a concern and it gives him more room for play in and out of the pool. He hasn't been over yet and so far I'm using the steps without them being connected to the deck. My steps came with a weighted piece that goes on the top step and two containers that bolt to the bottom that are also weighted. I had problems last year with build up of algae under the steps but so far I'm not having an issue with them not being weighted down and I can move them when I get in the pool to assure circulation BUT they certainly don't just "float" around. Any reason why I can't just leave them unattached?? At most, we have a day every other week or so where there are several kids in the pool - it's mostly us adults getting in and floating or swimming laps.
    We have straight steps. Last year I strapped 2 cinder cap blocks to a small brace on the bottom using electrical tie wraps to hold them on. Unconventional? Yes, but it held them down pretty well. Much less algea than the bag of river rocks I used the year before. (Did I say that out loud?) I thought about weights too, but wondered how they would react in a chlorine rich environment. Anyone?
    24' Round Leisure Bay Caribbean AGP
    Birmingham, AL
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    I did the same thing as TimWillin2 with my straight steps and so far it is working very well.
    JD
    csevel is offline Registered+ Thread Analyst csevel 0
    Cleveland, OH
    We also created weights for our steps out of PVC pipe which we capped off. Unfortunately, the gravel inside of them is not quite heavy enough to weigh our steps down. They only weigh about 25-30#s each. I think loading them with lead buckshot might be the answer. Last year we ordered the corner water bags used to hold inground pool covers down and they worked out great!
    Claudia
    18' Echo Canyon A/G Pool by Artesian
    8500 gallons
    3/4hp Jacuzzi 2-speed pump - Cartridge Filter
    Lehigh Valley, PA
    Quote Originally Posted by traceyb View Post
    That would be us. I'm glad the idea works for you. The URL is http://www.ellerbach.com/Pool/ .
    I've been trying to devise a way to reduce algae growth inside these type of steps.
    Water circulation is the key here, without it, it doesn't much matter what you do, you will still get algae growth.
    So, here's the best I have come up with.
    Add a second return directly behind the stairs, instead of an eyeball, fasten a length of appropriately sized hose into the fitting and feed this hose inside your stairs - either located at the top to point down or at the bottom to point up, if you are using solar heat, I would recommend pointing it up since heat rises, so the warmer water would have tendencies to rise therefore circulating well from bottom to top of steps.
    Well so far our Biltmore steps (straight) have no algae build up - they have all those flow through openings. However, I do tend to pour a bit of bleach there at the one side and top of the steps each time I run the auto cleaner - the water flows in a clockwise direction around the pool so the bleach poured before the steps will flow through them, the top it splash I give it is for good measure I guess. I have a super soft headed brush sprayer I use on the steps anyway and it shoots water into the corners.
    We weighted them with the sand filled bleach jugs. I was dissapointed to find out that the compartment that pops open in the front was not large enough to put another jug through though. We found out that another jug was needed to keep them down but had to use a wrapped concrete block instead. I think we will fill some pvc tubes with concrete and go that way.
