What to add during fill.
If lucky I'll be filling my pool this weekend. What should I be adding during the fill? I've seen people state they added Stabilizer while filling .Or should I fill it and then take a sample?
Also I understand I should use bleach to get the water up to a good chlorine level before turning on the SWG .. True ?
In ground plaster pool . About 21K gallons. SWG.
