Thread: Going below freezing: should I run the pump
    May 2014
    Ottawa, Canada
    Default Going below freezing: should I run the pump
    I have an AG chlorine pool, and it's going down to -6℃ (21℉) tonight and I'm not ready to close it yet. Should I run the pump to prevent damage from freezing?
    Everybody into the puel!
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Going below freezing: should I run the pump
    Yes. Below is a thread where Mark explains what to do. Not sure if it shows up as a link. You can always search this forum using the search box at the top right. If I may, why haven't you closed yet?
    http://www.poolforum.com/pf2/showthr...ing-conditions
    May 2014
    Ottawa, Canada
    I read that actually, but it was talking about Texas, and I live at least 10° north of that (maybe 15°). Also, I'm wondering if it considered which is the lesser of 2 evils: running a pump at that temperature or concerns about freezing at that temperature.
    May 2014
    Freezing is freezing, I would think.
    If the pump is running, the water would not freeze under normal conditions, just like running a faucet to prevent your pipes from freezing in your house. The pump will also generate its own heat. If you cannot winterize now, running your pump through all the pipes and fittings is the best option. However, winterizing is not that difficult, and the longer you wait the colder it will get.
    Jul 2013
    Northern Illinois
    I agree with Swimdaddy. Protect your pump and pipes from freezing.
    I haven't closed yet either... Working on it though.
    May 2014
    Ottawa, Canada
    You'd be surprised at how difficult it is to get this stupid thing closed. Every damn time I have trouble disconnecting the hoses, and I've already drained the pool, so there's no hope of running the pump, it's going below freezing that night, I panic and just about tear the skin off my hands trying to get them off!
  1. Pump operation during freezing conditions
    By Kidney in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-17-2014, 08:32 PM
  2. Freezing Reagents?
    By hawkeye91 in forum DPD-FAS based testing
    Last Post: 04-01-2011, 07:12 PM
  3. Clorox and Freezing
    By CyberGypsE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-05-2007, 07:23 PM
  4. Protect from freezing?
    By eljefe281 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-03-2007, 03:32 PM
