Re: Is it normal to have salt build up on pool wall under spa spill over in a SWG poo
It is concrete in-ground pool with tile under the spa spill over (I need to take and post a picture of the front spill over view).
Speaking of effervescence, I do have an issue with that on some of the bricks on the top edge of the spa. The brick used for the top ledge/seat has effervescence showing through the grout joints. You can see some of the damage along the top edge of the tile just under the brick and also in the brick grout joint
-Mike
20K in-ground pool, Pentair FNS60Plus Filter, IntelliChlor, IntelliTouch, IntellipH, SAM/SAL, two WhisperFlow 1.0hp pumps, Water Falls, RayPak, Jandy
