Results 1 to 10 of 28
Thread: How Long to Run Pump?
    Charlotte, NC
    Default Re: How Long to Run Pump?
    I usually run my pump on a timer 13 to 15 hours a day in 2 blocks. Generally 10am-8pm then 2am-6am. I like the pump on when we're swimming to take advantage of the water being stirred up. Also, I test and add chlorine when I get home in the evening (while the pump is on) to get the most benefit before the sun eats it up.
    Tom
    40,000 gal
    IG Vinyl
    Assuming I turn over my pool in twice in 12 hours should I divide pump operation evenly over 24 hours (e.g. on one hour/off one hour) , or am I better off running during the day in 2 x 6 hour hours during the day and 12 hours off at night ? Is there any advantage to running during the day versus at night (assuming at this point no one is in the pool). (I can turn on/off infinite number of times with home automation).
    thanks !!
    I run my pump 24/7 - but our electic rate is about $.05 kwh - so I honestly don't notice much of a difference in the bill. Now our winter heating electric bill is another story...
    I just really like how the water stays nice and sparkly with the constant filtration.
    Mine runs during the day to push water through the solar panels. If I run at night, it cools off the pool. I prefer to add heat and keep what I have so don't run after dark. It does run for 2 hrs in the evening for chemical additions but otherwise the timer is set to get max sun heat.
