Closed Thread
Results 1 to 10 of 39
Thread: Need instructions on opening a pool
    The South
    Question Good advice
    Thanks for the advice. However, I'm afraid to vacuum to waste because I"ll have to add even more water and dump in twice the amount of bleach to keep the level up. I'm doing all I can now to keep it at 12. It looks a little better every day. How often do you think I should be testing the cl and pH?
    22,000 gallon vinyl IG located in the heart of North Carolina
    Dec 2005
    South Carolina
    Default
    I'm not sure what kind of filter you have, but mine is a Hayward sand filter. My pool volume is a little less than yours too (18,000). I can spend 10-15 minutes vacuuming to waste and only drop the level down about 2-3 inches. That's probably 300 to 800 hundred gallons, but a small percentage of the total volume.
    I'd check the Cl at least twice a day (morning/night) and add the bleach you need to maintain the 12 ppm. Once you get things under control, you can test less often.
    Nater
    Honesdale PA
    Default Locking Thread
    This thread is way too long so I'm locking it. Littleheidie, if you want to pursue other specific questions please start a new thread.
    Thanks,
Closed Thread
